I mounted a classic retrofit ignition in my 911 3.0cs an gained about 13 hp. I have a 356 sc, is I possible to mount at classic retrofit ignition to that engine.
Best regards kasper
Yes, it should be.  You will need to use the 911 black coil.  In the CDI+ software you can change the number of cylinders to 4.  The CDI+ needs to know this so that  the RPM calculation is correct for the rev limiter function.
  • classicretrofit changed the title to Can I fit Classic Retrofit CDI ignition to a Porsche 356 SC
