Sebastien Posted February 10, 2023 Posted February 10, 2023 Hi, my old fuse panel had 2 upper terminal for one fuse so 4 wires Could fit in those 2 holes (2 wires per hole). I’ts impossible to put the 4 wire in a single hole terminal of the new retrofit fuse bar. So my question is : when an internal bridge is present on the upper panel between 2 or more fuse terminal ( like the fuse #4-5-6) can the upper wires can be put on any bridged terminal ? thanks ! Quote
classicretrofit Posted February 14, 2023 Posted February 14, 2023 Bonjour Sebastien, Yes, you can use any bridged terminal. This is covered in the install manual - bridging on our fuse panel is marked by white stripes. Quote
