Jonny Retrofit Posted July 4, 2022 Posted July 4, 2022 Here's how to setup launch control on CDI+: 1. Wire the yellow/black wire to either the clutch or a button on the dash so it switches to chassis ground. Ground is active. 2. Wire the red/black to a shift light ( 12v feed to a 12V Led, connect the ground side of LED to red/black. 3. Set the Launch Limit in the settings using our software. Default is 3000 just for testing the setup. Operation: Engine must be below 1500 RPM. Hold button or clutch for 3 seconds. Shift light will flash indicating launch active. When throttle is pressed, engine will hold on Launch Limit. When button/clutch is released, launch limiter will be deactivated (although normal rev limiters are still active)
