Start of season maintenance
Hi Jonny and CR team.
In anticipation of warm weather arriving soon, I wanted to check up on the health of my electro cooler in my '82 911SC.
I connected my laptop to the AC unit this weekend and checked the readings, settings and functions. I run the default setting that cam with the system in a single condenser configuration.
Everything looked good on the readings and settings.
Using the manual functions, the fan and compressor control worked fine.
I was concerned with the sound of the compressor. It made an initial "pinging" sound for the first 1-2 seconds before settling into a steady hum. I don't know if this startup sound is normal or if I do I have a pending issue brewing?
Thanks for the reply.
Now that the weather is warmer, I've used the AC a couple times and noticed it doesn't cool the cabin as it did last season. I ran a short log to see if you notice anything or if you can advise on what else to check.
I don't mind taking it to an AC specialist but it would be good to have your feedback before I book the appointment.
putty220617.logputty220617.log
 Share
