The Electroklima RS uses a simple arrangement without any blend valves, with air position controlled manually by adjusting the dash and under dash vents.
One of the key parts we reuse from the original Porsche system is the hose clamps. Make sure to save them from the removed parts. (this should go in the removal section???)
The supplied kit comprises of :
  • The direct footwell adaptors.
  • The underdash directional ducts
  • The windscreen step down adaptors
  • 40mm flexible ducting
  • 60mm flexible ducting
  • 60mm blocking caps
Block off original heaters:
Use two of the blocking caps to seal the top of the Sill
Recirculated Air Pipe:
Connect 60mm pipe from the blower to the original hot air feed hole in the bulkhead using the original grommet / edge sealer. Ensure the hose sits 50mm proud of the hole enough to prevent it from coming out of position.
In the frunk side these should go over the top of the windscreen vent tucked behind the scuttle.
Centre Vent (Passenger side):
On later cars with centre dash vent you can now connect that up. It is important to make sure the original scoop clips into the back of the dash correctly. It is common for these to not be seated correctly, which allows a large volume of air to leak behind the blower unit.
Windscreen air reducer:
Connect the 60mm to 40mm flexible adaptors onto the original screen plenum spigot,
This then connects to the blower using 40mm hose
Direct footwell adaptor:
The direct adaptors connect in using the original Porsche holes. The Underdash Ducts mounts from the bottom, and the adaptor from the top.
Ensure the block off section is forward in vehicle
You can now connect the 60mm hose
On the Drivers side it will come close to the Brake booster, you may need to create an indentation in the flexi pipe to allow it to fit.
Centre Vent (Drivers side)
We Recommend using our clock replacement vent, This gets a great blast of cold air on the driver which no other vents do. If doing this you can use the Centre Vent outlet to plumb directly into the back of it.
If not using any further side ducting the supplied block off cap can be now used on the blower.
Later cars (Big side vents):
On the later cars with the larger side vents you can directly connect side vents to the unused drivers side centre vent, you can then connect the passenger side vent using a T Splitter on the centre vent.
