Classic Retrofit Jack Posted October 2 Posted October 2 Porsche 356 We don't supply a 356 specific kit, but it is possible to build your own system using our components Before reading further please check out our main starting point to Universal systems' This will act as a starting point to the vehicle specific parts mentioned here. We have long supplied the key parts for Rod Emory and the Emory 356s, this had for a long time been made easy as his cars use the Polo 964 Derived 4 cylinder, so the alternator is the out the box 964 unit. Since 2018 we have sold Him countless systems Aswell as some others in the industry. The 356s systems have used several of the key components from the 911 A/C Kit, Like our condenser and shroud, Pump ECU Combo, Hoses and fittings. In addition to this we provide an off the shelf old school aftermarket universal blower. Due to the nature of most of these builds we do not have detailed pictures of the A/C Install however can share some finished instal pictures from the internet, it is important to stress that the mounting, Wiring, ducting etc is down to the installer. The installer will also need to complete a 12v conversion. Various suppliers like PRS have kits for this however they typically come with an alternator (Low output) Small AC Blower unit – Classic Retrofit Kit - Universal (Without Blower) – Classic Retrofit Includes, Condenser with shroud/fan 4m of each hose Drier and fittings Pump and ECU Wiring Loom for Pump Porsche 912 (65-68) Porsche 356 (55-65) Alternator Stand – Classic Retrofit Porsche 912 (65 - 69) Porsche 356 (55 -65) High Output 175A Alternator – Classic Retrofit
Classic Retrofit Jack Posted October 2 Author Posted October 2 We reached out to Rod, and he is happy for us to share some of the installations from public listings. Here is an example of installation
Classic Retrofit Jack Posted October 5 Author Posted October 5 Cabin Switches. Here is an example of our Blue Smart button used with our Electrocooler fitted in one of Rod's builds. It is mounted here so the driver can immediately see if the A/C is on or off using our smart switch function.
Classic Retrofit Jack Posted October 12 Author Posted October 12 Rough ducting for cars with 'Ray Guns'
