Jonny Retrofit Posted January 7 Posted January 7 Hose Routing There are many ways of routing the refrigerant hoses; see below for the for the basic circuit. As long as you follow this scheme, you can route the hoses as you wish. Note the placement of the charging ports. Please note that we provide 4m of each size which should suit most applications. Contact us if you need more but the goal is to minimise hose length to increase efficiency. Measure twice, cut once! Identify the fittings noting that there are two different hose sizes (#6 and #8) used. The larger #8 hose is used between evaporator and compressor and between compressor and condenser only. Position of charge ports is up to you and dependent on installation. Dry fit the hoses without the clips and cut hoses to size for your installation. The Compressor comes pre-filled with enough Refrigeration System Oil for the whole system, you do not need to add any oil to the system. Lubricate the O-rings on the fittings with POE Refrigeration Oil before installing the fittings to the Compressor, Blower, Condenser and Drier. Do not remove the compressor's bungs to use oil from inside it to lubricate the O rings as the Compressor should not be left 'opened' for more than 10 minutes.
Classic Retrofit Jack Posted October 19 Posted October 19 Heater Hoses Using the supplied heater hose. Connect up to the original heater feeds on the engine per the images below.
