The electric compressor sub assembly is mounted to existing holes in the chassis rail.  These holes are provided for the steering box on both chassis rails (to facilitate RHD and LHD installs).   E.g, on a RHD vehicle the compressor is mounted using the holes in the LH chassis rail.  The compressor is IP67 rated so suitable for 'temporary water immersion'.
The compressor sub assembly comes pre assembled.  Identify the holes in the chassis rail on the opposite side to the steering box.  The heavy black cable on the compressor uses one of the bolts for the earth.  Clean the chassis back to shiny metal on this bolt hole to provide a good electrical earth.
Right-hand drive compressor assembly onto chassis rail:
Left-hand drive compressor assembly onto chassis rail:
From under the vehicle, offer up the compressor to the inside of the chassis rail and attach with the three long M8 bolts and nuts provided.  Use one of the bolts to secure the black earth cable.
  • Martin P changed the title to 07. Compressor Mounting
