Mauricio Caceres Posted June 5 Posted June 5 (edited) I just finished the installation of the whole system. I kind of update the firmware and everything is looking good. The only thing that I need help is with my cabin control led is always ON. I started the system and trigger one of the fuses after a couple of minutes. Any ideas? I replace the fuse and tested again and the same happened. I check all the connections and seems to be fine. All the wiring and grounds look clean. In the Fuse box I connect. 1. 5A The two yellow cables 2.- 12V red cable 3. 15 A TWO Fans 4. 5A red cable from ECU Grey 5. The blue cables I DIDN'T connected. NOTE: I have a 1974 Porsche 911S and has some cables from the previous blower and regulators that I attached a picture. Maybe is that the problem? I attached a picture. Edited June 5 by Mauricio Caceres adding more info Quote
Jonny Retrofit Posted July 23 Posted July 23 Please can you post a picture of the black and grey connectors at the ECU. I need to see the wire colours. brown/yellow is the led wire. Quote
