Toby Pennycuff Posted December 31, 2024 Posted December 31, 2024 I saw the post regarding a power feed for the Turbo fuel pump fuse position (position 16). In my 79 930, there are already two wires feeding into Terminal 17 (A-Side) and it seems to be a pretty tight fit, so I am unsure I can get the Connecting Rail installed. The other complicating factor is that the gap between the two terminals may be slightly wider than the Connecting Rail supplied from Porsche. Would you suggest pulling a power source from Terminal 15 instead? Appreciate your suggestions here. Thanks. Toby Pennycuff Quote
