CDI+ and Pertronix
I am planning to use a 3 PIN CDI+ with a Pertronix System instead of the mechanical one.
any experience with this? I guess it would be straight forward as it Works as a replacement for the Bosch 3 PIN as well?
any changes to the wiring needed? Diode?
cheers
fokke
The original SC engine ran with the SC distributor and a 6 Pin CDI. I have no possibilities to check.
It got a bit better with installing a diode between the CDI+ and the pertronix.
I am running two CDI+ (twinspark config) with one pertronix.
Especially when I run both CDI+ in parallel with one Sensor the two units get confused.
Would it be necessary have two pertronix sensors?
Any experience with one pertronix sensor connected to two CDI+...I would assume that it should not be a problem as the sensor just switches to ground.
