snowhound88 Posted June 12, 2024 Posted June 12, 2024 Have dual condenser 911 unit and only have one condeser currently installed under left from wheel hub as instructed. 88 911 . When i am running bright AC blue light is activated and will start blowing colder air, and then the unit starts blowing hot air for a few minutes and then will come back on, Blue light indicator does not change color. Only happens when it’s hot outside but when outside temp in low 70’s does not do this. When I lift the hood i hear clicking from the compressor in the smugglers box. Eventually the compressor and condenser fan kick on and it blows colder air again for a few minutes and then it shuts off and the clicking repeats. Any suggestions to keep my.back from sweating so much Ha ha Quote
classicretrofit Posted June 13, 2024 Posted June 13, 2024 Good morning. Have you checked the system/gas pressure? Quote
Jonny Retrofit Posted June 13, 2024 Posted June 13, 2024 I would also check the high current red cables and their connections. Is it the contactor relay that is clicking? Quote
snowhound88 Posted June 13, 2024 Author Posted June 13, 2024 9 hours ago, classicretrofit said: Good morning. Have you checked the system/gas pressure? System was just charged a month ago. Quote
snowhound88 Posted June 13, 2024 Author Posted June 13, 2024 6 hours ago, Jonny Retrofit said: I would also check the high current red cables and their connections. Is it the contactor relay that is clicking? Not sure what’s clicking. What can click on the system by the compressor Quote
Jonny Retrofit Posted September 16, 2024 Posted September 16, 2024 The compressor can struggle to start if the battery is low. This can cause a clicking noise. Measure the battery voltage at the red cables near the compressor. Quote
