mooncake Posted June 10, 2024 Posted June 10, 2024 My 964 was fitted with a 240v motor and an electronic air conditioning kit, using ccu mode fan test normal,When the voltage is greater than 13v, input cmp=50 and the compressor cannot run Could this be a problem with the compressor? Quote
classicretrofit Posted June 10, 2024 Posted June 10, 2024 Thanks for your post. It is very unlikely to be a compressor fault. Have a look at this thread for our checklist as to why a compressor won't always start: This is a much more detailed troubleshooting routine for when the checks in the first thread are not successful: Finally here is some advice on 964/993 CCU specifics albeit the compressor has usually kicked in: Quote
mooncake Posted June 10, 2024 Author Posted June 10, 2024 8 minutes ago, classicretrofit said: 谢谢你的帖子。这不太可能是压缩机故障。 请查看此线程以了解我们的清单,以了解压缩机无法始终启动的原因: 当第一个线程中的检查不成功时,这是一个更详细的故障排除例程: 最后,尽管压缩机通常已启动,但这里有一些关于 964/993 CCU 具体细节的建议: I have tried, the blower is turned on, connected to a 47k resistor, and the voltage is guaranteed to run at 13v+ for more than 1 minute 1 Quote
classicretrofit Posted June 10, 2024 Posted June 10, 2024 OK, I have asked Jonny to look at your data and we'll see what he thinks. Quote
mooncake Posted June 10, 2024 Author Posted June 10, 2024 2 hours ago, classicretrofit said: 好的,我已经让乔尼查看了你的数据,我们会看看他怎么想。 When I press the snowflake button it turns into hipower Quote
Jonny Retrofit Posted June 12, 2024 Posted June 12, 2024 The trace looks ok (but I did notice that the BUT settings should be Latch for snowflake operation). I would look at the heavy current supply on the red cables. Try a direct connection of the compressor to the battery. Quote
mooncake Posted June 14, 2024 Author Posted June 14, 2024 2024/6/12 下午5点05分,Jonny Retrofit 说: 跟踪器看起来没问题(但我注意到设置了雪花操作的闩锁)。 我会查看红色电缆上的大电流供应。尝试将压缩机直接连接到电池。 My battery idle voltage is not high, and I have set BLO120. Can I get a better idle voltage by replacing a high-performance battery? Quote
Jonny Retrofit Posted June 20, 2024 Posted June 20, 2024 In normal driving conditions the compressor should not switch off. Try driving the car instead of leaving it to idle. Quote
mooncake Posted June 21, 2024 Author Posted June 21, 2024 17 hours ago, Jonny Retrofit said: 在正常的驱动条件下,压缩机不应关闭。试着把车开着,而不是让它闲置着。 There's only one problem. I don't think the cooling is strong enough How do I set a lower temperature? Quote
Jonny Retrofit Posted June 21, 2024 Posted June 21, 2024 Set CHI=95 Set CTS=18 Do you have our high output alternator? Quote
mooncake Posted June 21, 2024 Author Posted June 21, 2024 2 minutes ago, Jonny Retrofit said: Set CHI=95 Set CTS=18 Do you have our high output alternator? yes 240v high output alternator alreay install Quote
Jonny Retrofit Posted June 22, 2024 Posted June 22, 2024 Are you sure the compressor is running? On the computer, the current (CompI) should show about 75A when running. Quote
mooncake Posted June 22, 2024 Author Posted June 22, 2024 Just now, Jonny Retrofit said: Are you sure the compressor is running? On the computer, the current (CompI) should show about 75A when running. Yes, the compressor is running, but it feels a little cool, but not enough,The fan is also running Quote
Jonny Retrofit Posted June 22, 2024 Posted June 22, 2024 We need to see the DIAG trace with the compressor running ( e.g. CompI > 0A. ). Did you leak test the system? Quote
mooncake Posted June 25, 2024 Author Posted June 25, 2024 On 6/23/2024 at 6:27 AM, Jonny Retrofit said: We need to see the DIAG trace with the compressor running ( e.g. CompI > 0A. ). Did you leak test the system? With no leakage, the idle voltage will be low Quote
mooncake Posted June 25, 2024 Author Posted June 25, 2024 On 6/22/2024 at 3:14 AM, Jonny Retrofit said: Set CHI=95 Set CTS=18 Do you have our high output alternator? I tried this setting and the compressor didn't work again Quote
mooncake Posted June 25, 2024 Author Posted June 25, 2024 On 6/23/2024 at 6:27 AM, Jonny Retrofit said: We need to see the DIAG trace with the compressor running ( e.g. CompI > 0A. ). Did you leak test the system? When I set chi=95, the compressor often shuts down. When I set chi=90 cts=16 and keep 1500idle, the following data is obtained. The outlet temperature is about 20, is there any way to keep the outlet temperature around 10 degrees?I added 700 grams of snow, Quote
Jonny Retrofit Posted June 26, 2024 Posted June 26, 2024 You need to drive the car. If you let it idle, the system is designed to slow the compressor to low speed (SPD=001 on your trace) and the cooling will be less. When you drive, the voltage will pick up and the cooling will be better. 700g is a bit too much refrigerant. you might get better results with less - say 600g. Quote
Jonny Retrofit Posted June 26, 2024 Posted June 26, 2024 Also, are all your servo dampers working properly? It is very common to have heat flaps stuck open on these cars which will compromise the AC performance. Quote
