Mitch Covington Posted October 5, 2021 Share Posted October 5, 2021 Just ordered a CDI+ unit, but the car is not running. I suspect (hope) that my original Bosch CDI has failed, was running well recently. The instructions say check timing first, but obviously I can't without the engine running. Any special instruction for this situation? I'm assuming that the Classic Retrofit CDI product is actually 'plug and play' as advertised, and if the problem is indeed a bad Bosch CDI, I should be able to just mount it and plug in the 6 pin plug, without having to connect to a laptop... correct? Any other advice? I'm a DIY guy, but new to these CDI systems. Thanks in advance. mitch Quote Link to comment Share on other sites More sharing options...
Jonny Retrofit Posted October 8, 2021 Share Posted October 8, 2021 Yes, correct. The unit as shipped is plug and play compatible with the Bosch unit. Quote Link to comment Share on other sites More sharing options...
edmorales Posted April 1, 2022 Share Posted April 1, 2022 I have the same issue. The first 3 CDI's worked fine on the cars, Plug and play. This last 1 was ordered as a combo with the fuse box upgrade failed to start the engine. Fitting back the old one starts the engine with no problem. What is the warranty process for this? Quote Link to comment Share on other sites More sharing options...
classicretrofit Posted April 5, 2022 Share Posted April 5, 2022 Sorry to hear this - we bench test every single box before shipping so it should be fully operational. Warranty would be a full refund on receipt of the unit: we will refund your shipping if the unit is faulty. You can organise a return via an email to Jonny at info@classicretrofit.com. So the first thing to check in this installation would be the distributor signal. Check the light on the front of the unit is flashing when you crank the engine. Quote Link to comment Share on other sites More sharing options...
Jonny Retrofit Posted April 25, 2022 Share Posted April 25, 2022 On 4/1/2022 at 6:08 AM, edmorales said: I have the same issue. The first 3 CDI's worked fine on the cars, Plug and play. This last 1 was ordered as a combo with the fuse box upgrade failed to start the engine. Fitting back the old one starts the engine with no problem. What is the warranty process for this? Ed, we received the unit back but cannot find a fault with it. It tests fine on our test bench. Also, note the OP is saying that his Bosch CDI might be faulty, not ours! Quote Link to comment Share on other sites More sharing options...
edmorales Posted April 27, 2022 Share Posted April 27, 2022 On 4/25/2022 at 5:16 PM, Jonny Retrofit said: Ed, we received the unit back but cannot find a fault with it. It tests fine on our test bench. Also, note the OP is saying that his Bosch CDI might be faulty, not ours! Thank you for the input. We checked and the car is fitted with MSD Coil Regards Quote Link to comment Share on other sites More sharing options...
Jonny Retrofit Posted April 28, 2022 Share Posted April 28, 2022 On 4/27/2022 at 2:32 AM, edmorales said: Thank you for the input. We checked and the car is fitted with MSD Coil Regards That will 100% be the issue. Fit a standard Bosch CDI coil. We will return the unit to you. Quote Link to comment Share on other sites More sharing options...
edmorales Posted June 3, 2022 Share Posted June 3, 2022 On 4/29/2022 at 5:43 AM, Jonny Retrofit said: That will 100% be the issue. Fit a standard Bosch CDI coil. We will return the unit to you. Good Day, when can you send over the CDI? Regards Quote Link to comment Share on other sites More sharing options...
Jonny Retrofit Posted June 8, 2022 Share Posted June 8, 2022 It will go out this week. Quote Link to comment Share on other sites More sharing options...
edmorales Posted June 8, 2022 Share Posted June 8, 2022 31 minutes ago, Jonny Retrofit said: It will go out this week. Thank you for the update Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
