pocketscience Posted July 30, 2021 Posted July 30, 2021 Finally getting around to installing my issue 1.0 fuse panel into my 70T. Question re fuse 4 for headlights. On the original panel 3 and 4 on the smaller (8 fuse) panel are bussed. On the CR unit they aren’t. However input 4 (T9 on PCB) is connected to both the fuse leg AND the output of the relay. How can that be? Inputs 3, 1 and 2 don’t connect to the fuse leg and go only to the respective relay. Inputs 1 and 2 are bussed together same as the original. So I’m not sure how to fix this? Thoughts? Quote
Jonny Retrofit Posted July 30, 2021 Posted July 30, 2021 Some cars use an electronic dim/dip device that is incompatible with a relay causing it to ‘chatter’ (buzz). This is used to provide a low voltage to the dipped beam as a substitute for a parking or ‘side’ light. We provide fuse 4 as a non-relayed path to the dipped headlight for this reason. Just wire the panel as per original and it will work. You don’t need to add any bridges or wires between terminals. You will be connecting to terminals 1 and 3 only - the bridging for both L and R headlight is done internally by the panel on the output side after the relay. 1 Quote
pocketscience Posted July 30, 2021 Author Posted July 30, 2021 Ah ok, never heard of that. Was worried when there was nothing special mentioned in the documentation as well. Thanks for the quick response. Quote
