Fan relay wiring when not installing connector relay
Hi. I’m on the last of the wiring before sending it to the mechanic on Monday to test the system, then gas it up and switch her on. My (hopefully) last question is what to do with the wires that would have normally connected to the contactor relay if you don’t install that relay? Do I need to connect the gray wire that comes off the Grey ECU loom and the small black ground wire that is on the small loom labeled as ‘5’ on the wiring diagram? Cheers, Stu
 Share
