Where to put Temp Sensors (Porsche 993)
On the 993 suitcase you should still be able to place the evap sensor in the factory location for AC cars.  This is to the left of the expansion block as you look in the trunk.  Ideally the evap sensor is pushed between the fins of the evaporator.   The factor sensor is a long spike but you could use a long metal tube pushed into the evaporator fins and then put the sensor in the tube.
See here:
The cabin temp sensor should go under the dash where the inlet flaps are.
If the suitcase is still out of the car, you could also put the evap sensor at the back - again pushed between the fins.
  • classicretrofit changed the title to Where to put Temp Sensors (Porsche 993)
